We've just tried to install a 322 dual tuner using a dish 500 dp twin and a sw34 switch. When we check the switch, it just says 119 is hooked up. 110 never shows up. Any idea where to start
In that case, your dish is probably pointed a little too far right. Leave the cable connected, go to the point dish screen for 110. Have someone watch that while you try moving it slowly to the left, and see if you get the other satellite.
Mdonnelly is right. Here's how I would do this. Run one line to each receiver (322 and 625 sound like what you have). At each receiver, I would THEN use the DP Separator to "split" the line and hook-up each of those lines to SAT 1 and SAT 2.
Depending on who you ask, you can either do a checkswitch and software download at the same time for both receivers, or do each receiver one at a time. The DP34 switch sounds like a backup option in the event your receivers don't like the DP Separators. Good luck.
Ok..we have the dish 500 dp twin going to the dp 34, we bought a 322 that said it had a dp seperator..part #138138, i assumed (i know i know) it meant it was inside the reciever. If its not built in..then we're not using it. we've tested signal with a meter and both signals are good coming from the lnbs. the test switch shows 2 satellites hooked up..both 119 from port 1. Port 2 and 3 say n/c (not connected). we're not using the 2nd satellite at all (the 61.5 wing)
