Hey guys.
I am about to move into a new apartment and luckily i'll be able to install Dtv as my balcony faces south.
In my previous apartment I had the dish outside on the balcony with a single coax coming in the apartment to a swim box and then a single coax running to each of the two HD DVR's in my apartment (one in the bedroom and one in the living room).
My new place that i'm moving into is a townhouse so I do not want to have to place a coax coming from downstairs where the balcony is all the way through the living room, up the stairs, into the master bedroom and finally to the tv.
So my question is would the multi room setup work for me? I will have a broadband connection (probably from the local cable company) and I could setup the router in my master bedroom.
Would I be able to run a ethernet cable from the router to the hd dvr 23 in my master bedroom and then connect the other hd dvr 23 in the living room via wifi or vice versa?
I'm not really sure if you can even connect via wifi or not. Or does the multi room viewing still need a coax to each box from the dish?
Basically i'm trying to figure out how I can use both my hd dvr's without having to send a coax to the master and having to lay the coax throughout the townhouse.
Hope this makes sense!
Thanks in advance.
Thanks in advance.
