Don't you want to specify "swept to 3GHz" RG6?
RG11 is used for very long coax runs because it has more copper. It is seldom used in residential installations. Many years ago cable TV used RG59. With the need for higher bandwidth the standard, today, is RG6 except for very long runs.No,that's what I thought. Read alot on RG11 they say its alot better for hd maybe they switched , thanks
I thought it was because of lower attenuation, making it useful for longer runs. It probably has more copper as well, but at these frequencies, I don't think the signal penetrates very far into the material. Don't some coaxes take advantage of this by using copper-clad wire?RG11 is used for very long coax runs because it has more copper.
We use solid copper wire for Hughesnet/Viasat installs and runs between 100 and 200 feet because of the way it handles voltage. RG 11 is used for extraordinary long runs. In our case, the customer is responsible for supplying the cable, connectors, terminators, etc. I've only seen one job where the run was about 300' from the Dish to the house and while dBM's were higher, the system worked perfectly wellI thought it was because of lower attenuation, making it useful for longer runs. It probably has more copper as well, but at these frequencies, I don't think the signal penetrates very far into the material. Don't some coaxes take advantage of this by using copper-clad wire?
Aha; that makes sense. The lower the frequency, the more the signal penetrates. For DC supplies, of course the cross section of the copper is important to keep the resistance down.We use solid copper wire for Hughesnet/Viasat installs and runs between 100 and 200 feet because of the way it handles voltage.
Ambiguous. Did the customer supply RG11, or did you supply RG6? 300' would be spectacular performance for RG6.I've only seen one job where the run was about 300' from the Dish to the house and while dBM's were higher, the system worked perfectly well
No he supplied RG11 and the hardware. The solo Node was at the Dish with a Tap at the house. My fault for not specifying RG11Aha; that makes sense. The lower the frequency, the more the signal penetrates. For DC supplies, of course the cross section of the copper is important to keep the resistance down.
