I'm going to try out the CM-7777HD Dual. It's on sale for $69.99, down from $89.99. It has the ability to toggle between 17 dB and 30 dB. If it works better than my TVPRAMP1Z, which is 22 dB, then I'll use the TVPRAMP1Z as a backup.
I've heard great things (particularly price/performance) for that little RCA amp.
But if you're looking for a hotter amp, check out Kitz Tech's KT-500 preamp. It has a noise figure below 1 dB and have 36 dB of gain (adjustable). The biggest problem you'll have with it is overload...
The CM-7777 has been available for many years, I've had one on my antenna for 14 years. All they did was combine the CM-7777 (30dB) and the CM-7778 (16dB) into a single unit (CM-7777HD) to streamline the product line. Mine has the mast mount built in, no zip ties, and the connections are underneath, protected a bit from the weather. Works great BTW.
I would be concerned with the zip ties holding up exposed to the sun like that. Every zip tie I have ever used outdoors eventually gets brittle and fails. I might be tempted to use mechanics wire threaded thru the holes, wrapped around the pole, and twisted together instead.
I'm using the 30 DB setting and there is a noticeable difference but not a WOW difference and I was not expecting a WOW difference
My Johansson amp will kik IT'S but a just frum 15to,45:dbg uhf,noise is 3.4,24votls.
vh F 10to,30:dbg, God I love my stuff!!!!
Hummm, NascarKen is that you under there?
I’m thinking “Kyle” stands for Kyle Busch of Nascar fame?
Indeed it was. No more.Hummm, NascarKen is that you under there?
