I'm shocked that I can't find a huge thread addressing this topic. Maybe it's just in my area or something... (We get our equipment from Wood Dale, IL)
I'm an independent sub, and last Saturday we recieved a new shipment of Superdish mounting assemblies complete with telescoping strut kits. I didn't have the misfortune of opening it up and trying to use it until today. And I must say, that is by far the worst SD installation I've ever done. Whoever designed that assembly is an IDIOT. Whoever decided to SHIP those assemblies to technicians is an even BIGGER IDIOT.
The old SD mount had a large foot plate that had six locations for lag bolts. With the struts attached, there were a total of EIGHT lag bolts fastening the SD to any given surface. You could grab on and HANG from the mount if you wanted. I would even use it as a footing when peaking in the SD on steep roofs. NOW, with the new mount/struts, there is a maximum of FOUR locations for lag bots: TWO on the "foot plate" (I can't even CALL it a foot plate... it's too small really...") and one for each strut. That's right. FOUR freaking lag bolts are supposed to now hold a SD onto a roof. THAT IS INSANITY.
Once, about 6 months ago, I found myself short on lag bolts and time. I only had enough for three bolts in the foot plate, and one for each strut arm. The mount was secure enough, and I got a good signal, but I was just too darn paranoid about the thing comming off in a good strong wind. I went back on my own time and threw in 3 more lag bolts. NOW DISH HAS LOWERED THEIR INSTALLATION STANDARDS TO BELOW MY WORST PERSONAL STANDARD.
No lie: THE DISH IS LOOSE. You can grab it and SHAKE IT AROUND on the mount a few centimeters in any direction. The best peak I can get on these P.O.S. mounts is about 90 on 119 and 110. And it's not just me either. All the guys I work with are saying the same thing.
Also: With the old mounting system, you could actually forgo the strut kit in a tight installation location. Simply tighten everything up real good, use all 6 lag bolts, and you'd be set. No more. Now it's IMPOSSIBLE to install a SD without using the telescopic struts. Does Dish network WANT to loose customers? Many people are VERY particular about how and where the dish is installed.
It's so bad, that I can ALMOST convince myself that I'll only have to deal with it for a few days. Dish willl be FORCED to go back to the old system.
