I don't generally use the MAZ program, mainly because it only runs on one of my OLD computers for some reason (must interfer with things on my newer computers). But I just pulled that old computer up on my VNC, and started to run MAZ to check on something, and it told me that there was a new version, so I told it to go ahead and load it.
I think it was version 2.3 or something, not sure. At first I didn't notice anything different, but then I looked at the screenshot option, which USED to be just screenshots of the setup screens, but NOW it can do both setup screens AND the TV display. NEAT.
I was able to save the file as a .Jpg {the capital J was what MAZ said}, however it doesn't seem to display on my graphics program, it says the file is corrupted. I've only played with it for about 2 min, so I'll probably figure this out.
However I DID notice, that MAZ apparently tried to go into the Azbox and re-name one of my directories on the hard drive I had attached. I DO NOT LIKE THIS. Ie I have always been afraid of using MAZ, because it goes to about 4 or 5 different internet sites before it loads up, without permission, and it has scripts that change some of the protected partitions on the Azbox which are read only over to read-write.
I REALLY think that MAZ is a potentially dangerous (to your Azbox AND to your PCs) program, so I use it very seldom, and I'm glad that I only have it on an old computer that is only used for 2 things..... however this screenshot thing is pretty neat if I can figure out what's wrong with the JPG format it uses.
EDIT: after posting the above, I tried the screenshot thing again, while and switched again to the telnet function afterwards, and while I had the USB1 captures directory on my external hard drive displayed on the screen, rather than a TV screen.... the thing kind of bombed, but the most disturbing thing I saw was that a window asking for permission to switch the RW privilages of the Azbox RO directory had displayed, and it was stuck there... which is dangerous.
Anyway, once I switched back to a TV screen, I tried it again, and it worked again.
If you look at the Azbox display while doing the capture, the Azbox pops up a screen saying that a capture has been done, and apparently the Azbox transfers that file to it's Capture directory, but then the MAZ program moves that over to the PC, and deletes it off the Azbox. So apparently the Azox itself has a CAPTURE function that I didn't know about. I can't seem to find it on any of the menus.
Anyone know how to initiate the capture on the Azbox?
EDIT2: BTW, the captures of HD channels are good quality.
