Morning All
turbosat
I am honored by the offer (and quick acceptance by all here), yet when starting something new I derive the most pleasure in the journey not the final location.
Like when I picked up my first computer in 1982 and this journey is still being fulled today by Linux, there are many more (short lived) hobbies that I became proficient in and then lost interest (heck I'm on my 3rd wife), it is more about the learning than the doing (for me anyways). 30 years ago 1 of the things 1 of my mentors taught me is "you learn nothing from success, it is only when you fail the learning begins"
So anyways, I found 89 through 101 yesterday, actually they were always there, this was why I missed them. This Coolsat receiver has a signal and quality bar graph indicator that not only does it graph it switches between red (no good) to green and when I scanned the sky it stayed red on the linear LNB yet finding 91 through 110 on the circular. using the sat finding meter I adjusted for the highest pitch and did a blind scan and voila, there they were.
I'm not out of the woods yet, I've made a big mistake in dish placement, and goofed on my site survey. Earlier I spoke about using a compass, protractor with plumb line and a straw to survey my yard, well even tho it was accurate I missed something (nube mistake), the straw is 1/4 inch diameter where the dish is 36 inches in diameter so I need to trim some trees to get full signal.
My set up is off a hair in one (if not more) of it's axis my ark is not perfect requiring a slight elevation adjustment, I'll assume here and guess my true south is off a hair (well that's what my math is telling me).
A few thing I've discovered yesterday and have concluded upon (and PLEASE correct me if I am wrong) these LNBs are nothing more than VOCs (Voltage Controlled Oscillators) meaning the receivers must be very precise power supply.
An easier way to find true south (I believe) would be to adjust for your truest south sat for my location it is 71.8 = 181.02 them move to 101.01 = 220.60, having covered 30 degrees of my ark measure the amount of elevation change needed, then calculate the # of degrees rotation needed, or is there already an online applet out here that will do the math for you?
Or the non math way, (for my location) adjust for 71.8 drive to 101.01 and if the elevation has to go up that means I have to rotate a little to the west, if it goes down then a little to the east, I would guess 3 cycles of this should get you there (I'll test this theory today, this all came to me last night in the hot tube with a glass of wine and a cigar).
I'd better stop here, this is becoming a book
Later All
AFM
