I currently have a dish500 for 110/119, and another dish 500 for 61.5. I originally had two DP-21 switches to handle the two dishes with two lines from dish to house. I had a slight tree problem for 61.5, but rarely lost signal. I eventually want more than my current two receivers - thus my reason for moving to DDPlus.
I just tried a new DD-Plus LNB on my two dish set up. (removing the two dp21s).
Both dishes are on the samepost. I got the same poor results with two dish pro plus lnb's.. I changed cable connecting the two lnbs. I changed the 61.5 lnb.
For some strange reason, neither my 811 nor 501 will recognize 61.5 now!!!!!
I disconnected cable and reset both receivers and tried check switch again, STILL no 61.5.
I'm perplexed. I'm wondering if Dish Pro Plus lnbs require more signal strength to register as opposed to my original dp21 set up.????
I need to double check LOS for a 1000.2 before trying one of those, may or may not be an option.
any thoughts from fellow installers???
fred
fred
