N Nine Iron New Member Original poster May 6, 2016 1 0 Winder May 7, 2016 #1 Got a question. Ordered new Dish DPH EA LNB and Hopper 3 from Solid Signal. What bird do you peak the signal on? 61.5 or 72? Last edited by a moderator: May 7, 2016
Troch77 SatelliteGuys Pro Apr 4, 2015 4,182 1,206 Southern PA May 7, 2016 #2 Nine Iron said: Got a question. Ordered new Dish DPH EA LNB and Hopper 3 from Solid Signal. What bird do you peak the signal on? 61.5 or 72? Click to expand... The 72, but you still may have to do some fine tuning to peak both. Samsung Galaxy S6 Active Reactions: NR2D
jc1975 SatelliteGuys Family May 18, 2010 41 9 Chicago, IL May 10, 2016 #3 I'd also make certain your cable is connected to port 1 of your lnb and connected to the ODU port of your solo hub. I'd cap the 2 client ports on the hub with 75 ohm terminators if they're not going to be used.
