The analog shutoff does NOT affect Dish. It applies to over-the-air analog signals only. Sure, Dish might include NTSC tuners in their receivers, but that's just a benefit. They're not necessary to receive Dish's service/programming.It has got to happen. Manufacturers will not include NTSC tuners after 2009? Dish has got to make receivers with ATSC modulators for TV2.
Mike
TV's will be made with NTSC tuners for years after 2009, the only thing that will happen in 2009 is that OTA broadcasts will no longer be NTSC.
No tuner has supported UHF OTA NTSC channel 72 for years.
Whydo you think that Dish isincluding all those attenuators with the dual tuner dual output products for.
Its not an issue.
Speaking of which, I've seen posts from people with "monitors", i.e. TVs with NO tuners, set up for TV2 usage with a dual-tuner box. They can't use the coaxial (RF) feed to run TV2. You can't "tune" to the channel you pick on the receiver for the 2nd TV. Does the attenuator resolve that ?? I didn't think it did.That doesn't make any sense. If by some chance your remote TV doesn't have an NTSC tuner I don't see how an attenuator is going to help.
Its not an issue.
What attenuator? I do not believe I receives one with my 622. Perhaps i do not understand
I would think that perhaps dish can pump out 8VSB/ATSC but downrezzed to 480i on the RF ports.
Scott, can you explain what you mean by this ?? The manual says it's for filtering out "stray" UHF signals.Whydo you think that Dish isincluding all those attenuators with the dual tuner dual output products for.
But couldn't a low power ATSC/HDCP modulator eliminate the copying?On the tech chat last week this question was asked and answered. They said they couldn't do this due to the fact that the providers wouldn't allow them to provide a pure digital signal output that could be copied easily.
I'm assuming that ATSC VHS Recorders and DVR with DVD Burners and/or Hard Disk Drives are licensed to use HDCP which either allows a program to be recorded, recorded once, or not at all.
But then Vern, I'm confused.
