Need Some help on DPP44 switch instalation
ramimac
298
Las Vegas,NV
I was woundering if i could get one of the nice installers on here to give me some step by step instalation inscructions for the DPP44
as is what steps i connect the equipment switch power inserter and receiver and when to power the inserter.
Also weather or not a dp quad lnb will work or not?
Thanks for all the help
I have had realy bad luck with this in the past.
DPP44 won't function until it has power. A Quad should work - if you connect port 1 of the Quad to port 1 of the DPP44, and 2 to 2.
I recommend you read the manual that came with the switch. If you don't have one, why not? Then get one.
Failing DP34 switch
Uncovered- the Model 625 DVR Rip off
