I have the Channel Master CM5646 UHF/VHF/FM Antenna. I could get the nbc and pbs station in hd. The scanning on the 811 dish picked up 2 more dt stations but they were not strong enough to lock in. I added the Channel Master 7777 Titan2 VHF/UHF Preamplifier. It improved the signals I was already getting slightly but the signal on the other 2 didn't improve. I realize that the meter isn't a true meter but if they are strong enough signals to pick up on a search it seemed like the preamp would have done the trick.
Here is the list and the location. They are all in the same area.
uhf WAIQ-DT 26.1 PBS MONTGOMERY AL 244° 24.9 27 70%
uhf WSFA-DT 12.1 NBC MONTGOMERY AL 202° 42.4 14 - 94%
NBC is the most distant station and this one has the srongest reception by far.
uhf WNCF-DT 32.1 ABC MONTGOMERY AL 240° 23.8 51 -just dt no hd yet.This one flashes from 0-50%.
uhf WCOV 20 FOX MONTGOMERY AL 202° 42.4 20 (says they are hd but they are not on list and the scan did not pick them up.) still a little snowy
Montgomery, AL WSFA-DT [14] 600.0 507.0 dH 31°58'28"N 86° 9'44"W DT-LIC NBC
Montgomery, AL WNCF-DT [51] 58.00 246.0 dH 32°22' 4"N 86°15'42"W DT-CP ABC
17'30"W TV-LIC PBS
Montgomery, AL WAIQ-DT [27] 750.0 175.8 H 32°22'55"N 86°17'33"W DT-CP PBS
Montgomery, AL WCOV-TV [16] 1.10 156.0 32°20' 6"N 86°17'16"W DS-STA Fox
I got a uhf /vhf because I want to get vhf channel with the antenna too and I read where more hd channels would be added to vhf. I thought it might be because the other 2 aren't fully hd yet but it did pick them up on a search and the preamp(set to vhf/uhf) did not make that big of a difference. The antenna has been adjusted.Any Suggestions. Thanks
17'30"W TV-LIC PBS
