Hi Everybody!
I have an old Dish500 antenna sitting outside and I would like to get international channels from Dish programming. The channels are on 61.5 satellite. Obviously this is not a standard setup, so there is no help from Dish Networks on this quest. I have removed switch, directly connected one of LNBs and tried to point the antenna using Dish300 azimuth and elevation and to search around this area, but no success. I realized that Dish500 has two focuses (since it has two LNBs) and satellite does not sit on the line antenna is pointed to. But technically there is nothing impossible here. Has anyone here had experience with cases like mine and can help and calculate azimuth and elevation for zip 05446? Sinse both numbers would depent on which of two LNBs I would be using, please specify that too.
Thank you! I am relying on your wisdom!
