Need help with Pansat 9000
jacknk
4
se
I have a Pansat 9000 and I am trying to get a channel and must be doing something wrong. I can get it on a Sonicview using the same dish. The SV picks the channel up using the following settings.
LNB 11250
Transponder 12234
Symb 4439 H
Fec 3/4
Without moving the dish I put these setting in the 9000
LNB 11250
Transponder 12234
Sym 4.439
FEC 3/4
DVB-S/Qpsk
It shows I am getting a signal of 98% and Quality 71%.
When I try to scan the transponder the % stays 0 but the status bar moves across the bottom of the screen, but the scan never ends and nothing changes.
I am picking up a test pattern same satellite tp 12694 H 3.978.
Any ideas would be appreciated.
you need to change the LNB frequency to 10750 and do a scan
Looks like you're trying to get the RTV mux but with the wrong LNB frequency it wont work properly
RTV is at 11735
H
4440
I would just hazard a guess and it looks like RTV
Currently getting it on 12234 with a LNB LO of 11250
Change LNB LO to 10750 which is 500 less and that 12234 goes to 11734
Satellite-calculations look angle
SES2 87W
