Need help with my new 622...
mothergoose45
83
I have just gotten a 622 and it only connected to 1 TV. I hung a plasma that it is running and hid the 622 in an enclosed bookcase. I thought I could use the UHF remote instead of the IR but I can't figure out how. As of now I have to leave the door open on the bookcase for it to work. How can I use the UHF remote and make it work?
That remote is intended for your TV2 (remote TV) output, but if you put the 622 into the "Single" mode then TV1 and TV2 are the same (TV1 is HD and TV2 is SD and down-converted HD) and either remote will control what you're seeing on both outputs. You can toggle between the "Single" and "Dual" modes with one of the front panel buttons. Check your User's Guide for the exact instructions.
Even then, if you have the 622 buried in a cabinet it still might not work with the UHF signals. Make sure you have the UHF antenna correctly installed and oriented on the receiver back. You might have to do some tricks to get more signal to that antenna, like relocate it.
Also - make sure your 622 is getting adequate ventillation !!! I can't stress this enough! This unit runs VERY hot and any high temp. condition is likely to lead to early failure and might even adversely affect your other equipment in that same cabinet!
vip622 most likly UHF remote2 address is set to 1
Press Menu 6 > 1 > 3 to check remote address
Remote2
Press and Hold SAT Mode button till lights flash
Press 1
Press #
If you want to change uhf remote address
Remote2
Press and Hold SAT Mode button till it lights flash
Press (any number 1 to 16)
Press #
Press record
Make sure the vip622 doesnt get to hot: 622 Temp Thread
http://www.satelliteguys.us/showthread.php?t=59186&highlight=622+temp
Definetly. I am a nut when it comes to my electronic stuff. It is in a 3 ft by 4 ft cabinet by itself. It get enough room to breath.
I have tried what you mentioned above. The UHF works like crap. Wonder why my UHF from my 942 (thats in another room) will work from outside, but this UHF won't work with the door closed from 6 feet?
If that remote works at all, then the address must be correct, but you might still want to verify what JimK2 said. Possibly try a different address as well.
If that doesn't help, then try extending the UHF antenna from beyond the back of the 622. There are many comments on this topic. Try this thread:
http://www.satelliteguys.us/showthread.php?t=56001&highlight=622+UHF+remote
Thanks for the link. I can run some RG6 out of the antenna output up to the top of the cabinet connect the antenna antenna to that, drill a small hole in the top of the bookshelf (which is hidden)mount it there and that should do the trick. Never thought of that!
Should work for you! Do report back. I've had interest in doing essentially the same thing when I get a (proverbial) "round tuit". Right now the UHF remote is just on the margin from another room. If I move it around I will usually find a spot that works (and strain something in the process!). Just a nuisance. I think the raised antenna is the answer for me too...
In addition to what they all said...
If you are only running one TV, then as they said above, put the 622 in SINGLE MODE and either remote will work both TV1 Output and TV2 Output. You can use the 622 to get Picture-in-Picture instead of using the TV's Picture-in-Picture capability.
However, if in the future you decide to connect 2 televisions, or desire to use the TV's Picture-in-Picture, then you can purchase a UHF-PRO Remote for TV1. This remote is only sold by Dish Network Technical Support for about $39 + shipping. This remote comes with some removable tabs so that it will work either as a Replacement IR for TV1, a Replacement UHF-PRO for TV2, or a new UHF-PRO for TV1.
EDIT: Here's a different thread with some remote options: http://www.satelliteguys.us/showthread.php?t=83146
It definitely WORKS!
I ran a piece of white coax out of the back of my AV cabinet, along the baseboard, and then came under my speaker & hid the antenna behind the speaker grill.
Drastically improved my UHF remote #2 reception from the bedroom.
Great, SR! I was thinking of a similar solution, but I might just strip-off the coax outer jacket and shield to the same length as that antenna. Either should work just as well...
Question re: Dish Network at vacation home
Is Dish having a price increase?
