Need help with my dish network
Amin0786
4
greenboro, nc
Hey, I leave in Greensboro, NC. i have two dish one Big one is dish pro with dual HD LNB and one small small dish 500 with in LNB, I just replace the recevie to VIP612 DVR and Free HD channel and i have international channel but i am not getting all my HD channel and international are coming and going sometime there are losing single and i do not know what to do. please help.
Do you know which sats you are pointed at? Sounds to me like a 61.5/110/119 setup. Internationals have been moved from 61.5, as well as all HD except locals. Internationals have been moved to 118.7 and national HD to 72.7.
I agree that you likely have a 119/110/61.5 "mixed" arc setup, which will cause you to be missing channels.
Press menu-6-1-3, and tell us what satellites are showing up in field G
It is showing 110 118 and 119
ok i know but how to fix that problem.
It looks like your small dish is not hooked up. You would need to attach a cable from the small dish (D500) to your big dish (D500+). The small dish would need to be pointed at 61.5. Run a check switch after the cable is attached and the dish is pointed to 61.5.
i am getting international but not the HD channel.
Timer List Won't show more than 39 timers
very annoying 'cannot connect to dvr' message
