need help with dish settings
janzy
SatelliteGuys Guru
126
I'm using an ExpressVu dish with 2 double lnb's and a Coolsat 5000 receiver.
I'm really confused with the settings menu, can someone tell me what I should put into the following slots please.
LNB Power: ?
LNB Type: ?
LNB Freq.: ?
22khz: ?
DiSEqC 1.0:
Legacy SW: ?
not much on the ExpressVu satellites in the clear but the settings are
on
single
11250
(see below)
(see below)
off
The 22k and Diseqc depends on what switches you are using
the only switches on the dish are the ones that come installed with ExpressVu.
Which one would usually be installed?
walks like a duck . . .
As far as I know , BEV still uses legacy Dish switches (and LNBs).
You probably have an SW21, with the two double-output LNBs.
So far as I know, the Coolsat won't control those switches.
It will control: 22khz and diseqc.
If you want to receive real FTA, I suggest a different dish/LNB/switch configuration.
Thank you. I just ordered a motorized one.
Now, the "fun" will really start! Stay tuned!
0 skew for a BSC21-2
Starbox help...
