My Pansat 2500 went down so I ordered a "New" Captive Works CW800.
I also bought a BSC621 LNB.
Right now I am using my 10 ft. dish as a stationary dish , until I replace my motor and arm. When I was using the stationary set up with my C band I was able to hit several sats by using my compass and changing my elevation..
I installed my BSC621 and hooked it up to my new receiver, but I do not get a signal.
I hooked up the coax via factory diagram in order to receive K/C over one single coax. No signal.
I then tried a short coax to the K band and a short coax to the C band. Still no signal.
Where I get confused is with the Diseqc switching.
When I hooked up a short coax to the K band connection and a short coax to the C band I connected those to a CW4 1 Diseqc Switch and then I ran One coax to my receiver.
I hooked up the C band to Lnb 1 and the K band to Lnb 2 on the Dis switch.
When I would scan I tried C band with the receiver Diseqc on one for C band and also tried Diseqc two for K band. Still no signal.
However, I did notice when I ran both C and K short coax cables and ran that to the 4-1 switch I could turn my dish and the satellite, that I was close to, would automaticly show up on my receiver. However, I still could not get a signal. I would auto scan and blind scan and could not get a signal.
One thing I will check is the coax cable that I am using now because it is not the same one I was using with my old C band system.
I know some of you are using the BSC621 and may be able to help me.
THANKS
THANKS
