I still prefer the Winegard pop up 1000.x dish. That thing is magnificent.
The one I have seen is quite portable. Single cable run to it, similar to the tailgater, but is a full pop out dish. People throw it out on their tripod and work beautifully.
Really? I've never seen one like that and I've lived in RV parks and campgrounds for over 8 years now. I'd be interested in something like that if you could provide a link. Thanks.
No, it's an auto dish and may be the traveler but on a tripod. I haven't dealt with any of them since working the RV department which went defunct in 2012-13, so not sure how much help I could be providing a link. I don't RV or tailgate so I haven't looked into any in years. But for obvious reasons, that was my ideal situation
Just an update.... I just hooked up my new Wally receiver to my old Tailgater (gen 1) antenna. The receiver recognized that I was connected to a mobile antenna and did all of the setup and installation with out being connected to the internet or my home dish. It appears that dish has worked out the need for the Wally to be connected first to your primary dish.
I doubt that last line is valid. I helped a guy hook up a Wally and a new Tailgater last week. I don't know much about the play makers but I assume they work the same way. Have you tried to run a check switch manually? Menu/Home - Settings - Diagnostics - Dish - Test. see if a new check switch helps it acquire signal. Also, Wallys are odd. Sometimes when they stick on the Acquiring Signal screen, it;s because the guide is downloading in the backgroundI'm having trouble with my brand new Wally receiver and a brand new play maker. I use mine strictly for tailgating and I previously used directv with a g2. I actually made it through the process of setting up the Wally with a g2 and got to the step of activating the receiver and a prong broke off the power supply. I ordered the part but in the meantime bought a playmaker and it has been a pain. I am picking up 110, 119 and 129 but it will not acquire a signal. Do I need to hook it up at someone's home first? Or do I need to clear the configuration and try again? Right now I'm thinking I just need to fix my G2 and go with it. Thought? Suggestions? Also of not, the dish tech support guy told me that the playmaker is not recommended east of the Mississippi River because of the arc...
Yep, I did it that way. And it was stuck aquiring a signal for about 6 hours. Would it have taken that long?I doubt that last line is valid. I helped a guy hook up a Wally and a new Tailgater last week. I don't know much about the play makers but I assume they work the same way. Have you tried to run a check switch manually? Menu/Home - Settings - Diagnostics - Dish - Test. see if a new check switch helps it acquire signal. Also, Wallys are odd. Sometimes when they stick on the Acquiring Signal screen, it;s because the guide is downloading in the background
It is valid for locals. It's advertised for Western Arc only so only locals on the WA.I doubt that last line is valid.
Many areas east of the Mississippi have locals on the 129It is valid for locals. It's advertised for Western Arc only so only locals on the WA.
Sent from my KFDOWI using the SatelliteGuys app!
