Hi all,
I am new to this forum and have a problem that I cannot solve. I have nowhere else to go but here to you guys, as I am at my wits end with this.
I am getting "Searching for Satellite Signal, Please Stand By" message on my tv. However, sometimes, like maybe for 30 minutes a day, I actually get the signal and the programming, but when I switch channels, then I get the message and the signal is gone. I then go to check my signal strength and it says "Move dish 3 degrees". However I had a tech comeby and realign it to 91 signal strength, and I know that is is locked in at that, because when I do get the program I checked my signal strength real quick and it says 91.
I checked my connections and they are fine, I also did a hard reset and pulled the plug on my reciever and it didn't work. I also had my local satellite store check the reciever and they said it was fine. I have been told that maybe it is an LNB issue, but if it is why would I get a signal once in awhile, mind you very little at all anymore. My system was working perfectly for the past year, but this problem has started about a month ago, and I cannot get any signal pretty much.
I need help and any opinions you may have. I appreciate the advice big time. Thanks.
Brett
Brett
