Need help, please read, Canal 1 Internacional (Ecuador) free
inolepehc
5
Ohio
Hi all,
first of all, i don't know if this post belongs here, but i am a dish network customer so i guess if what i want to do is possible, that's one of the things to consider (again, not sure).
Canal 1 Internacional is an ecuadorian channel that was part of Dish Latino not too long ago, but god only knows why is not part of it anymore. now they have Teleamazonas Internacional instead.
Today I and many ecuadorians that live around the globe have received an email from Canal 1 Internacional letting us know that the channel will be free for anybody as long as you know what to do with this info that they provided:
Satélite: INTELSAT 805
Frecuencia: 4029 Mhz
Polarización: Vertical
Symbol Rate: 3. 000
FEC: ¾
Is there any way i can set up my current dish network service to pickup that signal???
please let me know, thanks a lot.
No. First, even though Dish's receivers use the DVB standard, they will only recognize channels provided by Dish. Second, a frequency of 4029 would be on a C-band satellite, which requires a much larger dish.
Jim, thanks for taking the time to answer this, really.
so, what would i need to buy in order to get this channel? could you please point me in the right direction??
i'm a newbie. :cool:
This is the area you need to ask help in. They will welcome you with open arms.
You'll get that channel free. And many others. After you spend some bucks on a big dish and receiver box. How much? I don't know. But I do know that often those big dishes can be had for free, or nearly so. And used boxes can be quite good deals. You need to post your situation just as you have above, but in the FTA forum. Click on the blue word above, and you'll be there.
Best of luck to you. And wish me luck learning Spanish with a little lady named Rosetta.
thanks navychop!! u r the man!!
buena suerte con rosetta, tiene un bonito nombre!
Yes, ask in the FTA section.
Also, ask if some one can make sure the channel is available FTA before you invest anything. Lyngsat lists it as encrypted.
Local Channels OTA on what Transmit?
Bypass fee waived only for 1st dual tuner DVR
