need help finding true south
nelu
15
i live in philadelphia zip code is 19116 trying to set up pansat 2700a with hh90 motor need help finding true south .thanks
Code:
                      Philadelphia, PA 19116
           Latitude 40° 6.996'N Longitude 75° 1.188'W
                         Sat Name Sat Lng Az(t) Az(m)   El  Skew
                     Intelsat 901   18.0W 112.7 125.6 16.2 -44.9
                     Intelsat 603   20.0W 114.3 127.2 17.7 -44.2
                            NSS 7   22.0W 115.9 128.8 19.2 -43.5
                     Intelsat 905   24.5W 118.0 130.9 21.0 -42.5
                     Intelsat 907   27.5W 120.5 133.5 23.1 -41.2
                   Hispasat 1C/1D   30.0W 122.8 135.7 24.8 -40.0
                     Intelsat 801   31.5W 124.2 137.1 25.9 -39.3
                     Intelsat 903   34.5W 127.0 139.9 27.9 -37.6
              AMC 12 & Telstar 11   37.5W 130.0 142.9 29.8 -35.9
                          NSS 806   40.5W 133.1 146.1 31.7 -33.9
                        PAS 6B/3R   43.0W 135.9 148.8 33.1 -32.2
                           PAS 1R   45.0W 138.1 151.0 34.3 -30.7
                     Intelsat 705   50.0W 144.1 157.0 36.9 -26.7
                     Intelsat 707   53.0W 147.9 160.8 38.3 -24.0
                     Intelsat 805   55.5W 151.2 164.1 39.4 -21.6
                            PAS 9   58.0W 154.6 167.5 40.4 -19.2
                         Amazonas   61.0W 158.8 171.7 41.4 -16.0
           EchoStar 3 & Rainbow 1   61.5W 159.5 172.5 41.5 -15.5
                 Estrela do Sul 1   63.0W 161.7 174.6 42.0 -13.9
                     Brasilsat B2   65.0W 164.7 177.6 42.4 -11.7
                     Brasilsat B1   70.0W 172.2 185.2 43.3  -5.9
                 Nahuel 1 & AMC 6   72.0W 175.3 188.2 43.5  -3.6
                        DirecTV 5   72.5W 176.1 189.0 43.5  -3.0
                            SBS 6   74.0W 178.4 191.3 43.6  -1.2
                            AMC 5   79.0W 186.2 199.1 43.4   4.7
                          Nimiq 2   82.0W 190.8 203.7 43.0   8.2
                            AMC 9   83.0W 192.3 205.2 42.9   9.4
                     Brasilsat B3   84.0W 193.8 206.7 42.7  10.5
                           AMC 16   85.0W 195.3 208.2 42.5  11.6
                            AMC 3   87.0W 198.2 211.2 42.0  13.8
              Intelsat Americas 8   89.0W 201.1 214.1 41.4  16.0
                 Galaxy 11/Nimiq1   91.0W 204.0 216.9 40.7  18.1
                     Brasilsat B4   92.0W 205.4 218.3 40.4  19.1
                        Telstar 6   93.0W 206.7 219.7 40.0  20.1
                        Galaxy 3C   95.0W 209.4 222.4 39.2  22.1
              Intelsat Americas 5   97.0W 212.1 225.0 38.4  24.0
                        Galaxy 4R   99.0W 214.6 227.5 37.4  25.8
                            AMC 4  101.0W 217.1 230.0 36.4  27.5
                            AMC 1  103.0W 219.5 232.4 35.4  29.1
                           AMC 15  105.0W 221.8 234.8 34.3  30.7
                          Anik F1  107.3W 224.4 237.4 33.0  32.4
         DirecTV 6 & EchoStar 6/8  110.0W 227.4 240.3 31.4  34.2
                          Anik F2  111.1W 228.5 241.4 30.7  35.0
                    Solidaridad 2  113.0W 230.5 243.4 29.5  36.1
                         SatMex 5  116.8W 234.2 247.1 27.0  38.3
          EchoStar 7 & DirecTV 7S  119.0W 236.3 249.2 25.5  39.5
  EchoStar 9/Intelsat Americas 13  121.0W 238.1 251.0 24.2  40.5
                       Galaxy 10R  123.0W 239.9 252.8 22.8  41.4
                        Galaxy 12  125.0W 241.6 254.5 21.4  42.3
             Galaxy 13/Horizons 1  127.0W 243.3 256.2 19.9  43.1
 Intelsat Americas 7 & EchoStar 5  129.0W 244.9 257.8 18.5  43.8
                           AMC 11  131.0W 246.5 259.4 17.0  44.5
                        Galaxy 1R  133.0W 248.1 261.0 15.5  45.2
                           AMC 10  135.0W 249.6 262.5 14.1  45.8
                            AMC 7  137.0W 251.1 264.0 12.6  46.3
                            AMC 8  139.0W 252.5 265.5 11.1  46.8
                     EchoStar 1/2  148.0W 258.8 271.8  4.3  48.6
        Satellite Finder is (c) Copyright 2004, P. Lutus
I would use SBS 6 @ 74.0W as a (close to) True south satellite.
http://www.lyngsat.com/sbs6.html
Using Sadouns GREAT web site your motor elevation should be at 40 deg. same as your latitude and the Dish (on motor) elevation should be at 39 deg.
http://www.sadoun.com/Sat/Installation/STAB-Installation-Angles.htm
Nearly forgot.......
WELCOME to the SatelliteGuys.US FTA Forum :welcome
You can use the Sun as a true South indicator. Use a vertical pipe (longer is better) that's plumb. Tie a string to the base of the pipe at ground level to measure the shadow of the pipe, when the shadow is shortest as measured by the string, the string is on a true North-South line.
A decent compass corrected for your local declination can get you within 1 degree.
pansat 2700a
Best time for news feeds?
