I currently have a Dish500 and a 300 pointed at 61.5. I'm using legacy with (2) 21 switches powering 2 dp receivers. Now my new 721 should be arriving today along with a dp twin, dp single and a dp34 switch.
It makes the most since to have the dp34 switch closer to the receivers so I wouldn't have to run as much cable. Does it make any difference if the lines coming out of the LNBs go into the ground block first, or into the switch then into the grounding block?
I also wanted to make sure that dp can handle a 100' run of cable before it reaches the switch. Will this work? My only other concern is that I recently read on a site that if you're going from DishPro to legacy, you MUST run a check switch with everything unplugged before plugging up the legacy LNBs and switches, probably because of the powering of the switch/LNB. Is there anything I should know before removing the old LNBs and installing the new ones?
