nbc dt 14 breaking up with good signal please help
Playaction
20
nbc is breaking up with 80 % and above while fox and abc hardly ever break up and they are in the 60's. I assume all are uhf.
epuipment-942
8 bow antenna uhf
titan uhf/vhf amp-it is set to uhf and the trap is off.
my zip is 36078
I had a uhf/vhf antenna before and nbc was fine but I could not pick up other stations so I switched to uhf antenna. I tried a joiner to hook up to both but it does the same thing.
The signal may be strong enough that you are receiving multipath reflections that oscillate in and out.
Try tweaking your antenna slightly left or right and see if that helps.
What do they mean by boom length?
Why can I only see digital OTA during the evening hours?
