Nashville TN Arc?
I am in a 2-arc area but I prefer WA because of SD locals and "higher" signal strength.
This is one reason Dish has so few options for adding HD RSN's and HD locals - they can't make up their mind where to put channels so they put the same channels EVERYWHERE.
They should bite the bullet and have each local ONLY on one ARC and free up quite a bit of transponder space for more channels.
All these dual arc locations are on spotbeam so if you remove channels you really do no good. You cant add national channels on a spotbeam.
You could **try** HD RSN's on a spotbeam but then you have to map it more than once due to spotbeams not covering the whole area of a RSN
Does the sports pack give you HD RSN's? If so you couldn't go to spots...
Programming DISH 20.0 IR Remote for Vizio VSB200 Sound Bar
Sling Link
