Latest update on my project:
Thanks to Windtamer, I have the necessary satellite ribbon cable to carry on my project. While I was waiting on the cables he sent me, I moved my Primestar dish close to the Wilson dish. I planted it nearly 10 feet from the other dish. Moving my Primestar 1.2 meter dish gave me a lot better LOS. There use to be a old oak tree that died and I finally had it removed, giving me great LOS.
I am using the Wilson dish for C-Band FTA and analog channels. I am using the US Electronics ORB-5000 for the analog channels while the Qualitv receiver receives the C-Band FTA channels.
I am using the Primestar dish with my Coolsat 8000HD receiver for all the Ku-Band channels. The Sg2100 HH drive is being used to move that dish. I took off that lousy circular/linear LNBF and replaced it with the standard Ku LNBF. I still need to finetune that dish. Still having the issue of bringing in the 123W satellite. I am hoping to have that done before my next surgery soon.
Today I replaced the BSC621-2 LNBF with the GeoSat LNBF I bought months ago from the members only special.
The reason I replaced the LNBF is this:
I was trying to piggy back my Qualitv to the ORB-5000. Here was the problem: Before I tied the Qualitv onto the ORB-5000 receiver, I was getting (99W) Tps 16 (Shepherd Chapel) and 17 (Color bars, writings) with beautiful picture screen. I tied the Qualitv in, and couldn't get
Tp 16 at all. I tried everything! Same problem. Even with the Qualitv off, the problem presisted.
So I remember the GeoSat Ck2 having dual outputs, and being 17 degrees. I switched out the LNBs and on one output, fed the cable to the ORB-5000, and from the other output fed the cable to the Qualitv.
It worked out GREAT!!! The Qualitv does not interfere with the ORB-5000, and the picture quality are excellent from both receivers! Wow!
Windtamer, the ribbon cable you sent me saved my project! Thank you, again for helping me!
