So, what are the proper entries for 110 and 119 satellite settings in the receiver for a DP Twin LNB? How are the two feeds distributed? Do both sats come through both lines, but separated into H/V. Or, is each line dedicated to a specific sat?
A DP TWIN sends both 110W and 119W down the same cable on the Horizontal (18V) with two LO frequencies. DP Twin LNBF has two independant outputs intended for two tuners. I have never set up for a DP, but it in therory it should be OCS 11250 / 14350. Someone .... correct me if I am wrong!
Of course. That's the first thing I did.
Do you mean 37? My latitude is 37.
Sorry, late night post .... 37 is correct .....
Dish elevation and Skew were correct from the beginning.
I did all of that, of course.
I will do this today after work, as I have a feeling that blockage may be my problem. I wasn't sure how to check for it, though. Thanks for this great tip!
I was going for E9/121. But, I would imagine that if I hit anything, I would have shown some quality, which never happened. Although, I haven't tried changing elevation, other than to correct my previous mistake.
If you did not select an active frequency for the satellite that you are attempting to locate, quality will never be displayed.
What is a "power scan"? The CS5000 has 3 choices": Auto-Scan, Blind-Scan, and Manual-Scan.
Iceburg got this one ...
Thanks. I'm glad I chose satelliteAV for my purchase! Of course, I only have time to work on the installation after 5pm on weekdays, and all day on weekends. (I assume the 8am-5pm time you mention is weekday-only).
Yes, but unfortunately I am often around VERY late with a few of the techs! PM me if you are stuck and we will give you a call if available.
