First, I am glad I found this place. I have pulled out a lot of hair.
I have a 2022 Keystone Springdale travel trailer. It has a cable coax connector on the utility side. It also has a Winegard Air360+ installed. The 360+ has a satellite line run into the RV adjacent to the Winegard wall plate.
I have a King Tailgater and two Dish Wallys. It is my understanding that the King only receives from one satellite at a time. Both receivers must be on channels on the same satellite. I have tried every combination of receivers and multiple switch checks and reboots and the slave receiver will never change satellites when the master receiver channel is switched to a different satellite.
Dish tech support is useless.
I have read here that the Winegard Trav'ler with the 3 LNB will work with my Wallys. I really don't want to pay 2000 bucks for a satellite antenna.
Is there an antenna that will work with my 2 Wallys? I am proficient at aiming satellites.
The Wallys are tied to my hunting ranch Dish which has a Hopper 3 receiver. I understand that the Hopper 3 will work with the 1000.2 3 LNB antenna but the Wallys will not. I need two receivers and am tired of trying to make this work.
Thanks in Advance!
Eddie
Thanks in Advance!
Eddie
