I just had a dual tuner installed (522). I am try/wanting to add a third tuner. However I believe the polarity is the same for both satellites (110/119). I did purchase a generic multiswitch and my dual tuner will only see "line A", or one of the satellites. Under inspection I found that 110 and 119 are using the same transponders. Is there a special switch that I must use? I was reading other threads and that is what it sounds like. Would a DP34 work?
My setup would be if you think it would work
Dish 500 --> Dual LNB dishpro-->DP34-->dvr522 + reciever4700 E*
On a side note I have been a E* person for sometime. When I upgraded to the 522 they switched out the old dual LNB. Should I ask for that back?
Thanks.
Toby
Thanks.
Toby
