I have a DirecTV system with Tivo. I have one antenna with dual LNBs, but only one cable runs from one LNB to the room where the DTV system with Tivo is. The other LNB supplies another system in another room. I wish to be able to see one channel while recording another, which means supplying two satellite inputs in the reciever.
I have a Dynex DS-Mx102 multiswitch, with two satellite inputs, one antenna input and four outputs. I planned on having this switch in the room and spliting the current cable in two, to provide for the two satellite inputs...
However, while reading this forum, I am not sure if this can be done.. One input has 13/14V and the other 17/18V, which confused me.
Does this mean that I have to connect both LNBs, one to the 13/14V input and the other to the 17/18V input, and then I can have 4 outputs, or can I just simply connect one LNB to either of those inputs and split the signal in two?
Thanks for your help.
