Today I bought a Channel Master 4x4 multiswitch, model 69041FD01, from my friend for $5.
Will this work with FTA?
Thank you, Tron for this info! I've been doing FTA for a year now and this is the first time I come across the 4x4 multiswitch issue. I want the best FTA has to offer and I want to find the best way to recieve them. While researching on the SEARCH feature of this great site, I saw a picture of Iceberg's setup of switches that included a Channel Master multiswitch.
I'm sure you'll find a great use for this switch. I like this type of switch more than the DiSEqC switches because they are usually of better quality than the typical $5 - $10 DiSEqC switch
agreed
PLus there is so much more you can do with that switch
The best thing of that multiswitch is you can hook multiple LNB's to multiple receivers with only one switch
output to up to 4 receivers
could have really 1-4 LNB's hooked into it
-4 LNB's...need stacked LNB's but it can be done.
I think JerryT explained it in this thread.I was thinking of that possibility as well.
Has this been tried?
In theory, it should work, as long as the switch can pass 2.1 Ghz...
Once I understood, I drew a couple of pictures to make it more clear.
Sounded good to me. Go talk to Jerry.
