What is ota and how does it work. I have a 722k duo reciever. Is it something you have to buy and add to your reciever.
Without a more specific location, that sounds pretty close for 129W.got satellite pointed 252degrees 22elevation no skew. Will this work? It's a dish 500 dish
Unless the OP unhooked the Dish500 as part of the repoint, this doesn't seem necessary. As must trouble as it is to disconnect it...Have you run a check switch test (menu-6-1-1-check switch-test)? What does it say when its finished?
Are you using a conventional compass or a declination corrected compass of some sort. The azimuth number given is relative to magnetic north as opposed to true north.The Dish was a dish 500. When the upgrade was done, a single Dish Pro LNB was put on it to get sat 110. My zip code is 23962. I want to know if i can point right at 252 with an elevation of 22 degrees, no skew and aquire signal. I have it where I think it should be and i'm not getting anything.
If you're truly getting 110 using your current EL, then the EL is too high for 129.
I have to reiterate the above statement.If you're truly getting 110 using your current EL, then the EL is too high for 129.
Have you confirmed that the mast is plumb?When we go through the check switch test, we can find satellite 110 but if we move it to where 129 should be, can't get a signal at all. Any help would be appreciated.
