Multi mixing
mojosolid
MAss
Hey guys, am trying to blend 119 from a different sat and a slim line triple lnb into one 6x8 switch due to line of sight issue. any good tips? slim 5 wont work here los
If you didn't know you can go without 119 now using the new slimline 3, which gets the guide data from 101 instead of the previous slimline that required 119 for guide data.
Unless you need the SD locals or spanish like dishrich said this may be your better answer.
Thanks but I neede the 119 for spanish! I would like to resolve the melding of signals issue I have in the meantime set the one set up on a triple sat and the others on the 6x8 for high def I couldnt get the mix right.
hook up vcr to standard rec.
Are you satisfied with your SD & HD Picture Quality
