It will still be some more time until all of them will be eliminated but will require a total revamp of the site. It really needs a revamp now. I have not changed some of the info on the site for a while so it does need some updating.
Stargazer said:Starting Feb. 1st only MPEG-4 receivers will be allowed in order to get HD programming activated.
It might be that all new HD channels added after 2/1/06 will be in MPEG-4, but you will be able to activate a 6000, 811, 921, or 942 after 2/1/06 and receive any MPEG2 SD or HD programming that is available.SummitAdvantageRetailer said:So basically what you're saying is that DISH will only activate 411/211/622's when you want HD from 2/1/06 on out? So if you have a used 811/921, you should activate them before 2/1/06 AND order HD programming or otherwise you can only watch SD. And once you turn off your HD programming on MPEG2 HD receivers, you can't put HD programming back on them if I'm deducing this correctly.
lakebum431 said:This could also be interesting for the EBAY market of these older receivers. Sounds as if the market will go to zero if people cannot activate them. It may be time to unload now.
This seems reasonable. Are you sure there isn't some misunderstanding somewhere Stargazer? What exactly did your source tell you? Any details about upgrades for 921/942 owners that don't want to loose 100% of the value of their investments?JohnC said:It might be that all new HD channels added after 2/1/06 will be in MPEG-4, but you will be able to activate a 6000, 811, 921, or 942 after 2/1/06 and receive any MPEG2 SD or HD programming that is available.
