Well after spending quite a few years in one spot it turns out that I’ll be moving.
And of course I will be moving my dishes with me.
The new place is a much, much bigger, much much nicer house and neighborhood. But the yard is a LOT smaller than this one.
My backyard here is like 6,300+ square feet. Pretty darn big. The new yard is just barely over 2,000 square feet. Not much room for three large, rowdy dogs.
I really don’t want to put the dishes in the backyard because it’s so small. Not to mention I’m going to have a lot of gardening going on which will make the yard smaller still.
This means I need to put the dishes on the side of the house. I have an area of 30 feet by 14 feet to work with. It will be fenced in with a 6’ privacy fence so things will get a bit tight in there with the 10 foot dish.
There is a house next door but it’s far enough away that the dishes will be able to see over it’s roof across the entire arc.
One of the problems I am facing is that the house/yard is at a weird angle to north/south.
Here, at my current house, my yard is in almost perfect alignment with north/south so my dishes face straight back.
But because of the alignment at the new place I can’t place the dishes flat against the side of the house, they have to be out away from the house to clear the wall. I also have two air conditioners and some shrubbery there. I can’t move the air conditioners and I don’t want to cut the shrubbery down, at most I will have to keep it pruned back because it can get really tall.
I’m putting the 10’ BUD, the 6’ KU (convert to mini-BUD), two 1m KU USALS dishes, and the three Dishnet dishes. Pretty much all the same dishes I have here now. But being that it’s in a very confined 14x30 area within a 6’ fence and with obstacles within, I have to be very fastidious in my planning it out.
I have to have them come locate underground pipes, wires, etc and mark them. Then I have to buy all new poles and weld anti-rotate rods to them, pay someone to dig large, deep holes then set the poles in place and fill them with cement. After all the trouble I’ve had with them here I’ve learned that this time they’ll be a lot deeper, bigger around and filled with a lot more cement. I can’t make mistakes at all. I can’t do it haphazard like it is now. If I mess up and have a pole put in then find out after that I put it where it can’t swing around without hitting something, I’m really messed up.
Line of sight is not an issue in that there are no trees or obstacles to be concerned with except making sure that the dishes don’t get in the way of each other. I’m thinking the big dishes go to the back, the smaller ones to the front.
I can’t take the dishes there to “try them out for fit” in advance, I have to do this strictly by math I guess. And math, is not my friend. I’ve got to have all the poles set permanently in place then move the dishes after the fact, and hope that I didn’t totally foul it up.
Are there any tips I should know about that would take the guess work out of this? I would like this to be a scientific, precision operation with no mistakes because I only get one chance to get it right and it has to be right the first time. Sc*** ups not allowed..
Thanks..
Thanks..
