Mounting a Slim Line 3
gatamaz
4
vermont
I want to pole mount a Slime Line 3 in the ground. I have a heavy duty 1-5/8 inch pole. Do I need to have a 2 inch OD and if so is there a sleeve to put on my 1-5/8 ploe?
A slimline will spin on a 1 5/8 pole. I've seen adapters on eBay made out of plastic that are supposed to work.
I thought there would be a problem with the 1-5/8. Does anyone know what to search for on ebay for the plastic adapter. I haven't found it yet.
I found some pipe at Home Depot that was about 2-1/4 inch OD. What is the max OD you can use?
I have one sitting in the garage made of plastic, it works well, I use it for the camping sat set up.
That said, I would not choose to use it that way FULL time.
Thanks for the response. I have used the 2 inch PVC before but would prefer steel. We do have a garden tractor place in town. I will try them.
Dish grounding question, 2 ground rods
Lost Speed HD and Other HD channels
