Shepard's Chapel on transmits one channel. The preprogrammed transponder was only temporary with 3 channels and is no longer active.
Just scanned 99w Galaxy 16 C-band on a DJ-1997. Shepard's Chapel scans in as "SC HD Feed 1" and is on:
TP Frequency: 4006
Polarity: V
Symbol Rate: 5833
The Manhattan 1997 does not have a Pilot ON/OFF selection.
Does your feedhorn have a blue color servo motor for polarity control or did you update the feedhorn to a new LNBF? If the feedhorn still has a servo motor, are you using your 450i as a polarity controller? If so, is the polarity set to Vertical? If the feedhorn has a servo motor, but you are not using the 450i, manually input the above frequency and symbol rate, but set the LNB polarity to H (to supply the LNB with the proper 18V). No decimals are entered, only 4006.
METV Ozarks channel is on 99w, but the METV network feeds are on 101w. What other channels are scanned? Are you sure that you are on the 99w satellite?
TP Frequency: 4006
Polarity: V
Symbol Rate: 5833
