Mine showed up yesterday as well. Not sure why was never on before had to go into settings, Notification settings. Hit MoCa status icon, select your choice it will go away. Good luck
When I worked for Dish the majority of the time a simple system reset was needed at the Hopper location and it cleared up any problems. If you are repeatedly getting the popup you can either disable it the way Bubba mentioned, or you can double check all of your connections on both the problem location or the Hopper itself to see if any or loose/damaged.
There is even a MoCA health screen if you really want to see if there really have been any problems with MoCA or its current state among all devices. I set mine to disply ONLY if there are problems, and only a few times for very brief periods were they even any problems
