This is a new one for us.
A new client asked us to investigate why he's not receiving transponders below 10 on his DN 211 someone else installed a few months ago.
All three receivers indicate good signal level in the mid 40s on the active transponders
The absence of a detected switch is unusual because the customer is in a condo complex where the signal from a single dish on the 119 satellite is shared among other residents, first via a fiber optic backbone, then converted to copper wire for the last leg into the condos.
One would assume there is some kind of switch or splitter being used. We haven't seen this type of behavior before in a multi-receiver environment but we're not familiar with fiber optic and it's not our distribution install so we didn't want to go poking around in there.
Other residents haven't reported this problem. Anyone have any suggestions?
1. Our technician connected another 211 to the satellite cable. Initially the receiver was able to detect signal on satellite transponders below 10. After performing the Switch test, the transponders below 10 disappeared. Also, the switch test resulted in no switch being detected or identified.
2. Our technician then connected a model 311 to the satellite cable. Initially this receiver was also able to detect signal on satellite transponders below 10. After performing the Switch test, the transponders below 10 again disappeared. This switch test also resulted in no switch being detected or identified.
The fact that three different receivers all indicate the same result confirms that the problem is not within the receiver. 2. Our technician then connected a model 311 to the satellite cable. Initially this receiver was also able to detect signal on satellite transponders below 10. After performing the Switch test, the transponders below 10 again disappeared. This switch test also resulted in no switch being detected or identified.
