Missing Sat 61.5
kenroj
13
Been having a problem with sat 61.5 dropping out and then coming back online. the picture will be fine for a couple of days, then I start seeing pixeling on the screen for about and hour then I get the Acquiring signal on sat 61.5 and the sat is gone. I then run switch check and sat 61.5 isn’t there. If I wait awhile like next morning and run a switch check, 61.5 come back with signal strength of 75%. This has happen about 4 times in the last 2 week. Any suggestion, before I call to set up appointment to have it checks?
Ken
Check all of your cable connections that have to do with 61.5, if they are good and the dish is stable it will most likely be the LNB.
thanks, I'll check the cable connection tomorrow. I'm thinking it's the LNB.
ken
VIP 722 - 2nd tv (HDTV) question
Missing Channels
