No, read it again, That post took an additional step to format the HDD, my suggestion does not erase any info, nor reformat the hard drive.
Menu - System set-up - Diagnosis - then in quick succession, info - right - left - . Screen should come up. When you hit info again, should/might see message of corruption. Unplug the receiver, wait a couple of minutes and plug back in.
The right/left is the advance button like when you are in the guide, not the DVR buttons.
I have never lost any settings or recordings, when doing this, EXCEPT when my hard drive was corrupted. But then it really didn't matter I needed a new receiver anyway. Your mileage may vary so you do this on your own............
That's what also happens with me. Everything works properly for 2 or 3 months, then there will be a few missed beginnings. Then the cycle repeats.
I wonder how many instances of this are not reported or recognized because a lot of people just think a program started a bit early & dismissed the issue.
Have you compared the Start Time to the AV Recorded time as mentioned in the original posting? Please LMK if the times are different.
The times are different. The actual recording start time is shown and is later than the scheduled time.
That is what I was attempting to answer - Yes.But what about the "AV Recorded"? Was is different than the "Start Time"?
I got the new DVR up & running & guess what. The very first program I tried a scheduled recording on started recording 2 minutes later than it was set for. Being a new DVR the default 1 minute early start was used. But the AV Record indicates it started 1 minute after the hour.
The recording indicates it is 31 mins vs the 34 mins it should be. That means the recording was clipped be 3 mins. This 2 min vs 3 min discrepancy seems pretty typical & probably is a result of rounding off the time. It would also explain why when I started 2 mins early and the AV Record indicated a 2 min change that I still missed the beginning of the program.
I don't know where to go from here.
