I am using a new MicroDH for many months for recording broadcasts to my 500Gi hard drive without any problem. Note that I always left MicroDH on 24/24. The box was set for monthly auto updating firmware.
Yesterday, the box did not able to connect to my USB hard drive (only a green light is on):
1.- I removed this hard drive and connect it to my computer.
2.- The computer can read all files in this hard drive. After copying all file to the computer, I reformat this drive and connect it back to MicroDH.
3.- The box still had difficulty to connect to the hard drive (only a green light is on). I reset MicroHD, re-install antenna, perform Blind Scan, set clock and set 6 pre-programmed records. Disconnect/reconnect the power cable. The box still shown only a green light.
4.- I remove the drive again and connect it again to my computer and found that two test files and a directory is created in the drive by MicroHD. Reconnect the drive to MicroHD, this time MicroHD shown two green lights and I can access hard drive.
5.- I tried manual recording for 5 minutes and it works very well.
6.- The problem is that MicroHD does not execute any pre-programmed recording settings. Recording date, time... are checked carrefuly many times for each setting.
Could you please advise.
