Purchased a Mercury motorized system from SatelliteAV.
Having difficulty obtaining S or Q greater then 9%.
Zero problems (great signal, great quality) with a CW Premium, Coolsat 6000 or a SonicView, all hooked to the same motorized (and unmotorized) setup.
True south sat. is G10R and is the one I'm making comparisons from.
My setup is:
90CM dish
Invacom qph-31 (port 4 linear)
Diseqc port 3
LNB setting - single
using default TP from 3/17/07 factory file
The other receivers set up with identical configuration, and using the same dish average around 70-80 signal and 58-65 quality.
I have tried every combination of diseqc and usals and have gone as far as to disconnect the motor with the dish pointed and dialed in to G-10 ku.
Tried all the different scans with no luck so far.
My first problem with this box was erratic motor control which seems to have cleared up now, but, I still have the above issue.
Voltage from the box to the LNB and motor is good 18+ and 13+.
Any ideas or thoughts about what I may have overlooked?
My setup is:
90CM dish
Diseqc port 3
