I am setting up a dish & receiver and am getting nowhere. Adding insult to injury, I am close to being taunted by my wife. Currently, we are in the "why don't you hire a professional stage".... I am still acting as though I am in control, but am losing altitude and fast...
Consequently, I am questioning some of my basic assumptions. Any help will be greatly appreciated. Basically, I get signal strength up to 84% but no quality.
1. My LNBF make is:
DMS International Model ACS321S
RF: 1.17 ~ 12.2 Ghz
IF: 950 ~1450 Mhz
Should set the receiver settings to Standard or Universal? (currently is set to standard)
2. 22Khz setting is off. Is this correct?
3. Skew is at 45. Is this correct?
4. I am in Potomac, MD. That is Lattitude 37 and Longitude 77 degrees. Based on this data, Noaa's site indicates that declination is 10.37 degrees West. As such, I figure my true south is at 190.3 degrees. And my TS satellite is AMC5 @ 79 degrees.
Did I get this right?
5. Based on my coordinates the motor manual suggested that th elevation setting on the motor should be 53 degrees and the dish bracket set to 24.
Many thanks in advance.
1. My LNBF make is:
RF: 1.17 ~ 12.2 Ghz
IF: 950 ~1450 Mhz
