Make sure the DiseqC position saved is 0 before you switch from USALS to DiseqC otherwise the motor will automatically start moving to the saved position without you realizing what is going on.
The behaviour of any receiver is directly related to the version of firmware being used. What version firmware are you referring to when you say the above? I am using 2011Aug30 S9 firmware since I've found this to be the best firmware including improving the timer performance so the PVR is useable (with perhaps the reported glitch for daily recordings) and adding multiple column layout for scanned stations. The motor control of this version doesn't compare favorably with my Coolsat 7000 which operates exactly as one would expect it should....The s9 and S10 behave identically so diseq works very well as the day to day motor control.
I use an S9 with a universal LNB set for 10600, 22kHz ON so I only blind scan the high band. Just learned this from another forum: "With S9/S10, when using DiseqC 1.2 motor controls and manually "bumping" the motor position, the signal meter cuts out on vertical, making it difficult to impossible to peak on vertical transponders."...I just find that once the sat is locked in, a lot easier to adjust with a bump here or a bump there using diseq than to fuss around with USALS settings...
