yes LPB is DVB-S2
Which would probably make it next to impossible to get using a dual band LNBF on PortaBUD. If they made a stacked C-Ku Band LNBF, I'd give it a shot though...
yes LPB is DVB-S2
Have been trying to receive and view the LPB channel at the 87W satellite using the Fortec Lifetime Ultra as well as the Viewsat Ultra with no results. In the matter of fact none of the PBS channels come in at this satellite location.
LPB is DVB-S2 and those 2 receivers only receive DVB
Once we have the new DVB-S2 receiver, would we need to worry about the AC 3 issue of sound. Would the new reciever decode the sound to the Tv? Just asking! Thanks.
not really. There isnt much S2 on KU other than PBS. ONce in a while some sports feeds but most are still DVB. Use the Coolsat 5000 all day Saturdays scanning for football feedsThat was my point, those two receivers are almost obsolete.
Correct. Everything is moved that needs to be moved.Looks like LPBS has left 125 early, no signal on the transponder all day.
Cost.My question is, why did LPB move anyway?
No. DVB-S2 8PSK 3/5 has nearly equivalent C/N requirements to DVB-S QPSK 3/4, but with 42% more payload capacity.I could imagine if the signal was hard to receive for us, it was hard to receive for member stations with large 6.1 meter dish antennas too.
You pay for occupied bandwidth in MHz. How you use that bandwidth (modulation/constellation/FEC) is up to you and will of course affect throughput.If they lease a transponder, don't they have to lease all bandwidth of a transponder, or do they have the option to lease only part of it for a cheaper price? And whether you have a 25mbit transport stream modulated DVB-S or S2, it still uses the same amount of bandwidth, no?
DVB-S2 is good for anyone who wants to use less bandwidth (MHz). That translates into reduced recurring costs. LPB previously occupied 20 MHz but currently uses 15 MHz. I can tell you the amount saved dwarfs the incremental capital that was needed to move to DVB-S2 three years ago.From what I gather, DVB-S2 is best for larger bandwidths or very high bitrate streams, as most of those streams contain mpeg4 video, does this mean PBS will eventually transition to mpeg4 or am I just speculating?
IRDs with SDI and HDMI output can be had for under $1500 that do S2 and H.264.Since I use commercial equipment and have a mini headend set up on my clothes closet, DVB-S2 and mpeg4 trouble me greatly, as good commercial equipment is super expensive and hard to find second hand.
I'd guess you have 18 months left, but I'm speculating.I hope the PBS HD feeds on 12140MHz stay for a very long, long time in mpeg2 and DVB-S.
ifb said:Cost.
You pay for occupied bandwidth in MHz. How you use that bandwidth (modulation/constellation/FEC) is up to you and will of course affect throughput.DVB-S2 is good for anyone who wants to use less bandwidth (MHz). That translates into reduced recurring costs. LPB previously occupied 20 MHz but currently uses 15 MHz. I can tell you the amount saved dwarfs the incremental capital that was needed to move to DVB-S2 three years ago.
ifb said:PBS will move to H.264. Encoder evaluation is in progress. Note that LPB and PBS each make decisions that are in their own best interest. Each has different technical and operation requirements. PBS doing H.264 or DVB-S2 doesn't mean LPB or any other member station must follow.
ifb said:IRDs with SDI and HDMI output can be had for under $1500 that do S2 and H.264.
[/QUOTE]ifb said:I'd guess you have 18 months left, but I'm speculating.
My question is, why did LPB move anyway? I could imagine if the signal was hard to receive for us, it was hard to receive for member stations with large 6.1 meter dish antennas too. I never particularly like the move to DVB-S2 for any signal, and most signals that have transitioned over would work fine on DVB-S, like LPB, but I guess it's done to future proof themselves.
Iceberg said:I posted my thoughts earlier in the thread on why they moved
This is good. Nice strong signal on 87W (with the new satellite) and also unlike the national PBS stations which are on 125W because they need to be CONUS (as in all PBS stations have to grab the feed) LPB is only for Louisiana...87W works good as its near their true south (91W is true south in Baton Rouge)...less issues with rain. After all a dish aimed that far west has more susceptible to rain fade than one aimed pretty much straight up
The satellite operator doesn't "pass" savings, because there isn't savings. It's a similar business model to an ISP. You have the cable/DSL package that's $50/month for 50 Mbps. You spend money to get a new computer that can play AVC video files. You can now pirate movies that are half the size but look just as good. You decide to save $25/month and drop down to the tier that's only 20 Mbps. There's no savings to the provider, but you cut your monthly bill in half and all you had to spend was the cost of a new computer. Oh, and the old computer was out of warranty and about to die anyway so you had to get something new.This explains quite a lot. I still don't understand how it reduces cost. If I'm an uplink and I only use 15MHz and the rest is not being used, how does the satellite operator pass along the savings?
PBS provides IRDs. The current Sencore IRDs are modular, but they are also end of life. I believe the plan is in fact to replace them all.Each member station will need to upgrade equipment. I think they use IRDs that accept different input cards and such, but then they'd need the expensive mpeg4 to mpeg2 transcoding equipment.
MPEG-4 AVC and DVB-S2 solve separate problems. You can do one without the other. Also consumer devices are an entirely different issue. What a provider uses for contribution has no effect on what end users receive. ATSC is still MPEG-2 (theoretically you could do AVC, but we'll ignore that). I don't know what the rules for cable are, but AFAIK only IPTV providers are using AVC.Still very pricey compared to DVB-S mpeg2 equipment. End point devices like tuners don't decode mpeg4 yet, like TiVo.
