Does anybody have any idea how often I might expect to lose all local channels (via satellite) assuming no bad weather? I had that twice in my first six days.
Virtually never. Are you sure it is only your local channels? Without further info that's all can help you with. (What locals and or what satellite ARC, have you checked your signal strengths....)
This all sounds reasonable. I checked the weather radar and there may have been a storm in Greenville SC where, I suspect, the uplink is.It is possible if there is bad weather where the signal is sent up to the satellite for there to be a brief interruption, but it is rare when you have good weather to lose it.
Looks to me that you are on what is called the Eastern ARC, and your locals are on the 61.5 satellite. Can you figure out how to see the signal strength of that satellite? (Menu, system setup, installation, point dish) Put the satellite on 61.5 and see what signal strengths you are getting, and are they pretty solid or do they go up and down alot? If you continue to have problems, sounds like you have a new installation, just call them and tell them they need to come back out that you keep losing the signal.
... Can you figure out how to see the signal strength of that satellite? (Menu, system setup, installation, point dish) Put the satellite on 61.5 and see what signal strengths you are getting, and are they pretty solid or do they go up and down alot? If you continue to have problems, sounds like you have a new installation, just call them and tell them they need to come back out that you keep losing the signal.
I live in western NC and I frequently lose Channel 13 in Asheville. It usually lasts only a few minutes and doesn't happen on any other channel. I just suspect a simple uplink problem. It has happened in good weather also.Does anybody have any idea how often I might expect to lose all local channels (via satellite) assuming no bad weather? I had that twice in my first six days.
