lost HBO showtime encore comedy central hgtv sundance channels on 811 fed to plasma. still receive HBO and showtime hd channels most of 180 package and locals.
the 721 is unaffected-receives all SD channels.
i have two dishes running into an SW 21. one is dish 500 with legacy quad. dish is pointed at 119 and 110. 2nd dish is 10 yr old single lnbf pointed to 61.5
problem started earlier this week. i ve rebooted three times with no change.
system info shows software p339. st 110 and 119 are green. 61,5 is red with a cross thru it. from this i would assume that its a problem with getting the 61.5 signal-but i get the Boston/NH locals that are only on 61.5 just fine as well as all hd channels and other info channels that as far as i know are only on 61.5.
its been raining pretty steady for most of this time but the situation did not change in the few weather breaks we have had recently.
i ve emailed dish tech but of course have had no response. i thought i d have better luck here. any help would be appreciated by forum response or pm to dunncottage@gmail.com
did a checkswitch which was fine. signal strength on 61.5 was in 40 range on some transponders and 60 range on others. 110/119 signal strength was in 60 s for some transponders but most above 80 s.
