Hi
I replaced an sw-21 with a sw-44 switch, so I could get two tuners for my 622
I never got a great signal on 110, in high 70s due to trees.
Well, some hd was freezing and DSCHD wasn't even coming in last night
I checked levels, 2 are way up at 98, but the rest of dish xponders are at 42-52
I know that is too low.
I do have the sw-44 power inserter in port 1 as needed, and I had to connect the 2nd wire from the 110 dual lnb to the switch as I didn't need it before. The wire looked fine, but could corrosion on the connectors from the wire hanging unused for 3 years cause this much loss? On the wire connector? On the LNB connector? The lnb connectors are exposed, as this is an lnb strapped to my 119 lnb a few years back.
Should I try a new connector on the wire?
I want to know why it is so low before I futz with putting it all back to sw-21's
