clayface1000 said:It still mystifies me as to the rationale Expressvu used to make these transponder changes. For instance, the HD PPVs are on transponders that can still be received down here, yet, there's no way a southern subscriber could actually purchase an event. So why didn't they move these channels to the new transponders? Same thing with SRC-HD and the preview channel. Proportionately, there can't be THAT many people in the US who are clamoring for these channels compared to SN-HD and TSN-HD, which surely must be the two most popular overall. So why did they kill those two channels, and in the process, probably lose a lot of revenue from subscribers who will be forced to quit their service?
angiodan said:Fan, how far south in Florida are you, and what size dish are you using for 82? If you are getting all the HD channels, then maybe there is some hope for me.
As I mentioned in an earlier post, I'm near Fort Myers, and just using a Dish 500 setup.
BTW, if you get that engineer, I'll gladly chip in!
I was wondering, what type of email reply would you get back from Evu if you asked them why they can't move PPV's to the weaker transponders. Not give your real name, use an email that can't be identified with your account. State that you know that they are not legally able to provide service to the US, but there are plenty down here that have it, and they will changing to Starchoice since the sat shuffle because of the HD loss.
They'd probably not answer, but I'd be curious on the response if they did.
clayface1000 said:Pro96, yesterday I went to the retailer you recommended to me in Glendale (Calif) and picked up a 90 cm dish and a great $10 signal meter!
I did a temporary installation today, but took it down because it was so big and I got cold feet about my homeowners association. I was able to get a signal of around 49-51 on the transponders where CTVHD-E and W reside, along with SN-HD -- and reception of these channels. I'm undecided about doing a permanent installation, but in the meantime I had a question for you.
I was sold a 11250 LNB that was designed to fit on the new dish, and was told it was compatible with Expressvu. (Which was verified by my googling the subject.) However, I was unable to get my receiver to "see" the signal, which was run through an SW-21 switch along with a standard dual LNB, which was situated at 92 degrees. It's clear that the new LNB worked, as I was getting a very strong signal with my signal meter.
I slipped the 11250 LNB out of its holder and duct-taped in a genuine Expressvu LNB in its place. This configuration worked fine and my signal findings above, were based on this.
What's wrong with my configuration? Is the 11250 LNB incompatible with an SW-21? What are my options if I decide to do the permanent installation? Are there other switches I can use, or perhaps an adapter for the LNB? I did an extensive web search but couldn't really come up with the answer.
Thanks again for your help!
M Law said:Anyone ever answer this one? I want to know as well, cause as soon as I have a little free time, I'll be putting up a 1 to 1.2 mtr. It would be good to know the fixes before I run over the problems.
angiodan said:I got my hands on an elliptical dish as I had mentioned in another thread.
Well, I had a couple of hours to mess around with it this morning before work, and unfortunately, I'm still out of luck on the no signal tp's. The other tp's went up about 10-15 points, with 5 and 9 going to a lockable but unviewable 40%. 7, 11 and 27 are still big goose eggs. I was hoping for something, then I could have gone bigger. (Now I sound like my wife!)
So, I think it is safe to say, the footprint cutoff must be between Tampa and Fort Myers for EVu 82.
I'll be posting this in the other thread as well.
Thanks Ice and everyone for your help.
clayface1000 said:As it turned out, the retailer sold me a 10.75 GHz LNB meant for Ku band, rather than the 12.75 GHz one I needed for Expressvu. I had to educate myself, as he insisted that he had sold me the right one and the receipt reflected that. A few days ago, I couldn't tell you the difference between one and another, but after surfing the web for a while, I finally figured it. I talked to the retailer and he'll swap me for the right one tomorrow. So back up to the roof I go!
pro96 said:Glad that will be resolved.. now if only it would not rain this weekend here in Socal![]()
angiodan said:It's a 36" x 24" elliptical that Directv uses for its international programming like the pic below. I removed the 3 lnbs, and just used the middle one. (Not the Sat C as instructed by Iceberg!)
Fan, I was hoping I would pick up something on the 7,11, and 27. If I recall with the N1/N3 shuffle a couple of years back, it was a pretty dramatic loss of signal over a short stretch of mileage.
digiblur said:That dish isn't going to get you the gain your looking for. Your looking for a straight up 36inch offset.
